Learn How to Sew: Sewing Cushion Covers Learn How to Sew: Sewing Cushion Covers
Sewing cushion covers is an easy, cost effective way to update or transform any piece of furniture. Whether you are covering a chair cushion, a couch cushion or bench cushion, follow these instructions to make simple covers that will compliment your decor.
Step 1: Measuring the Cushion Cover
Measure the length and width of the top and bottom of the existing cushion. Add 4 inches to the length measurement and four inches to the height measurement to account for the seams. You will be purchasing 1 yard of fabric for every 3 feet measured. Measure the height of the cushion.
Record all the measurements, because they'll be needed when designing the pattern.
Step 2: Purchasing the Fabric and Closures
Choose fabrics that are durable and will withstand repeated use. Make sure to buy at least 1 yard of extra fabric to match any strips or patterns. Purchase a roll of hook and loop tape. These typically come in lengths of 1 to 3 yards.
Step 3: Making the Pattern
Cut a paper grocery bag so that it lays flat. Discard the bottom of the bag. You may need to put several bags together to fit the measurements of the entire cushion.
Using a measuring tape, draw the measurements of the cushion's top and bottom face onto the bag(s). Remember to add the 4 inches to the length and 4 inches to the width measurements. To make the pattern for the sides of the cushion, follow this formula:
- Length multiplied by 2, plus width multiplied by 2.
Cut a strip that is the length of that sum. The width of the strip will be the measurement of the height of the original cushion. Remember to add 2 inches to both the length and width of the strip.
Step 4: Sewing Cushion Covers
Pin the patterns to the fabric and cut. Make sure to cut 1 piece for the top of the cushion and 1 piece for the bottom. Remove the pins from the pattern and the fabric. You may want to save the pattern for later use.
Pin the ends of the long strip of fabric together and sew a 1-inch seam. Remove the pins.
With the seam lines facing toward you, starting at the center of the back of the piece that will be the cushion's top, pin the sewn strip all the way around the top piece. Sew a 2 inch seam around the two pieces.
Pin the bottom of the cushion to the bottom of the long strip of fabric. Sew around the front and two sides of the two pieces, leaving a 2 inch seam.
Step 5. Adding the Closure
Cut a length of hook and loop tape that measures the same length as the back side of the cushion. Sew one side of the tape to the long strip of fabric and the other to the back of the cushion. Put the old cushion inside the new cushion cover.
Need a new sewing machine? Compare brands, types and prices with our Sewing Machines Buyer's Guide.
