Liquid Tire Repair: Pros & Cons
Liquid tire repair is good to have in those emergency situations when you are traveling in your car and you develop a tire flat. A liquid tire repair kit can help you apply a temporary fix on the flat and get on the road in order to take the vehicle to the nearest tire repair shop to be properly fixed or repaired.
Depending on the type of liquid tire repair that you buy, you can apply a temporary fix in case of an emergency that can last for many miles until you can have a professional look at it. This is helpful should you find yourself stranded in some remote area and are miles away from the nearest repair facility.
Pros for Liquid Tire Repair
Carrying liquid tire repair in your car provides you with a quick tire repair when you need it. The obvious pro for keeping liquid tire repair handy and available is that you will not be stranded or without a way to take your car to a repair shop. Liquid tire repair that is designed today has the ability to travel far and instantly seal a tire leak as well as patch a small tear that has developed on your car’s tires. This is even more important should you find yourself with an unreliable spare tire.
Liquid Tire Repair is Inexpensive
Liquid tire repair is an inexpensive quick repair option. A liquid tire repair kit can cost between $5 and $50, depending on which repair kit you purchase. Coupled with a reliable foot pump, you can apply the fix easily and be on the road again in a relatively short amount of time.
Cons Against Liquid Tire Repair
Using liquid tire repair may give you a false sense of security when it comes to the repaired tire. Liquid tire repair is meant to be used as a temporary fix for a leaking tire. A more permanent solution involves taking the car to an auto tire repair shop to be properly patched or replaced. If you apply the liquid tire repair and continue to use the tire without making the required long-term repair, this could lead to a tire blowout or other failure and place you and your passengers in peril.
Liquid Tire Repair Can Be Messy
Working with liquid tire repair can be messy. The adhesive used to seal the leak is sticky and can get over you hands if you are not careful when working with it. It can also get over your cars upholstery or other clean areas on the car when you are through applying the fix.
Having liquid tire repair available is a good idea and every car owner should keep a kit in their vehicle’s tool box. You should be aware that using liquid tire repair is a temporary, not permanent solution to your car’s tire repair needs and the car tire should be taken to a tire repair shop immediately after application.
