Maintenance Tips for Rubber Roll Flooring
Rubber Roll Flooring is largely preferred, since it reduces the number or edges and seams, preventing moisture seepage to a greater extent. Rubber roll flooring is a bit more expensive than rubber tiles, and needs some basic care. To care for your roll rubber flooring, use the following tips:
Getting Started in Rubber Roll Flooring Care
After installation of the rubber rolls, wait for at least 72 hours to walk upon the flooring. This time is needed for the adhesive to properly bond. Stepping upon the flooring before the stipulated time can cause crumpling of the flooring, and shifting of the underlying adhesive, that compromises the durability. This tip is also applicable whenever adhesive-based repairs of a sections of the rubber roll flooring is done.
Regular Cleaning Tips
Sweeping the rubber flooring regularly is perhaps the best way to ensure that the grime is removed without harming the rubber surface. Please note that this refers to dry sweeping or mopping. You can use a vacuum too, but ensure that the vacuuming strength is set to in a low-to-mid range. Though the adhesives used in rubber roll flooring are quite sturdy, continuous high-power vacuuming can weaken the bond.
Stain-removal Tips
Use a mild cleaning solution, prepared from dishwasher soap and lukewarm water. After cleaning, remember to thoroughly dry the rubber surface with some old rags, or by turning-on the fan. Don’t use acidic cleaning solutions, as they can react with the rubber flooring and induce permanent damage. Don’t use scouring pads, as they can permanently scar the rubber flooring surface, being highly abrasive in nature.
Ensuring Luster of Rubber Roll Flooring
Use a rubber floor conditioner for sustaining the glossy finish of the surface. Prepare your own gloss-inducing conditioner, by mixing 2 teaspoons of powdered fabric softener into a 1/2 bucket of water. Dab the rubber roll flooring periodically with this homemade solution.
