Make A Bubbler Fountain In 5 Steps
  • 1-4 hours
  • 50-75
Container such as plastic bin or wide bucket
Submersible pond pump
Rigid pond tubing
Decorative rocks
Shovel
Small saw (for the tubing)
Rigid pond tubing
Decorative rocks
Shovel
A bubbler fountain is an attractive and fun addition to any yard or garden. Bubbler fountains provide soothing sounds and lend a tranquil nature to an area and the best part is that they are easy to construct. Here is a simple design that you can follow to make your own bubbler fountain in a five easy steps.
Step 1. Choosing the Location for Your Fountain
There are several factors to consider when choosing a location for your bubbler fountain. Sunlight is an important consideration for the placement of your fountain. Spots in direct sunlight will cause your fountain to quickly loose water through evaporation.
Areas located directly under trees with leaves that may drop into your fountain and cause clogging should also be avoided. If the ground is too rocky or root filled you may have trouble digging out a level space. Another important considerations for fountain placement is power. Make sure that you choose a spot that is close enough to an electrical outlet that you will not need to run an overly long extension cord. Most importantly, you should choose a spot that is attractive. Make sure that your fountain is not obstructed by shrubbery or in a spot that looks out of place.
Step 2. Choosing Your Water Container
The basic design of the bubbling fountain involves placing a watertight container into a hole up to its rim and then putting decorative rocks above the container for the water to flow down. To do this, you must pick a suitable container such as a small barrel or plastic bin. Make sure that it is not too deep, about a foot or two should be perfect. Also, make sure that the container is wide enough for your design.
Step 3. Digging a Hole for Your Fountain
This step is fairly self explanatory. Dig a hole that is deep and uniform enough that your container can rest in it with its rim flush with the hole’s rim.
Step 4. Creating the Pump Apparatus
Now that you have your container in place it is time to add the pump. You will be using a submergible pond pump. It is best to choose a pump with the water output on the top. This will make adding the tubing easier. Take a length of rigid plastic tubing that is long enough to reach from the pump to where you want the water to pour from and attach it to the pump’s water output using sealant or calking if necessary. If you cannot find a pump with the output on the top you can use a piece of flexible tube to turn the rigid tube upward.
Step 5. Adding the Rocks
This is the fun part! The idea here is to create a mound of rocks that are placed such that water will flow down them in an attractive way. To start you will need to create your base structure. This will consist of larger rocks arranged to fill the container to its rim. When arranging the base structure it is important to protect the pump and to ensure that its water intake area is kept clear.
Once the base structure is arranged, fill the container with water and turn on the pump. At this point water should begin to pour from the top of the rigid tube which is sticking straight up from the center of the base structure. With the water running, you can build up the rest of the rock structure, placing rocks wherever you wish to flow the water. Build the pile up to a peak and try to arrange the rocks so that they hide the top of the tubing.
There you have it! For very little money and just a bit of work you have created a wonderful, animated decoration for your garden. The basic design that you have created can be manipulated to include other elements such as sculptures, bowels or shells. The simple structure that you have to work with will allow you to express your own unique style.
The article needs to be rewritten because it is not formatted correctly and does not fir the article type. You've laid out the steps of "how to" install a flagpole, but the formatting is wrong; please make sure you format articles EXACTLY as detailed in the DIY Style Guide. Also, the article type is "informational", so you shouldn't write a step by step process. The article should contain helpful tips or caution to take with the project. You could write on different types and sizes of flagpoles along with their specific costs, for example. Please read the style guide thoroughly before you begin the rewrite.
