Manual vs Power Concrete Trowel: Pros and Cons
Trowel concrete is very important to concrete finishers for power trowel. They usually know what they require: some like ride-on or walk-behind trowels. Some even demand for 24, 36 or even 48 inch rotors for their trowels. But we need to remember that there are many other factors that affect concrete trowels and this leads to determining whether or not one concrete finisher will buy a trowel for his work. The engine size, type, steering mechanism and other details often lead to choosing the right power trowel for your requirements. Here is a detailed account of what to buy when manual or power concrete trowels are concerned. The basic options are ride-on power trowels versus manual power trowels.
Power Concrete Trowels
Steering is basically the most important detail and feature of ride-on machines when it comes to power concrete trowels. The options for such trowels are manual and powered. The powered concrete trowels are done by mechanical levers to adjust the rotors in order to gear the machine forward, backward, right and left. Companies have now engineered models that are assisted by power. They involve hydraulic steering and offer automatic steering as well. They are a little expensive and heavy on the average mechanic’s pocket. That is the disadvantage of a powered concrete trowel. But they are easy to maneuver and they ease the workload. You will be pleased to know that powered concrete trowels work on overlapping rotor models. These bigger models are offered with five to six huge blades for better work. Make sure you check the additional features of each in order to compare them better.
Manual Concrete Trowels
Some mechanics still remain in favor of manual machines. They find their prices easy to afford and their mechanism far more understandable as compared to powered concrete trowels. The powered concrete trowels are assisted systems that are joined with torque converters and changeable speed clutches. This helps the operator to work at a slow panning. It also gives the operator the option of high-speed burnishing with the very same tool. There is also a debate concerning the usage of gasoline and diesel when it comes to these machines. Gas engines are common and advantages that give them the likeability factor. However diesels are used in enclosed areas by trowels as well. But the disadvantage of a powered concrete trowel working on diesel is the health factor. Adequate ventilation for such a concrete trowel user is very important. Therefore gas engines remain comparatively better to use. Walk-behind concrete trowels are less sophisticated as compared to powered automatic concrete trowels. But some are now offered with high-tech features. The size of a manual and a powered concrete trowel varies as well. The size of the engine is a little smaller which means swifter work can be done. Lightweight powered concrete trowels are now being manufactured for mechanics worldwide. Some walk-behind manual concrete trowels have better advantages over the powered concrete trowel because of their dual-rotor machine.
