Marble Mantel Shelf Pros and Cons Marble Mantel Shelf Pros and Cons
A marble mantel shelf is elegant and attractive. Once installed, it becomes the point of focus in your home. There are pros and cons to consider when installing a marble shelf as outlined below.
Pros of a Marble Mantel Shelf
Marble shelves are available in a wide selection of colors and textures. It is, therefore, very easy to get the color that matches your décor. It is also easy to dye it to the color of your choice. Marble is very hard and durable, requiring very little maintenance. All you need to do is wipe the shelf with a damp cloth regularly.  A marble mantel shelf is easy to install and following the correct guidelines, you can do it by yourself in a few hours. Besides, marble is porous and therefore very hygienic, as it does not harbor bacteria.
Cons of a Marble Mantel Shelf
All the above advantages of a marble mantel shelf come with a high price. The shelf is quite expensive. At the same time, the shelf stains easily and may end up looking very unpleasant. A shelf made from darker marbles shows stains less and you should opt for it if it matches your interior design.
