Matte Knife Matte Knife
A matte knife is a small sized knife that is used to cut items such as paper and cardboard. This knife is especially helpful with matte boards and other items that might need more exact detail. A matte knife is often used in craft projects.
What Does a Matte Knife Consist of?
The main structure of a matte knife is a plastic or metal cover that houses a blade. The blade itself can vary; however, they are usually a standard size. You can purchase a matte knife that is bigger or smaller depending on your project’s needs. The concept behind the matte knife is to produce an exact and sharp cut.
You set the blade down on the desired location and run it down to the point where you want to end the cut. The result is a smooth edge, and if done correctly, straight. The matte knife comes with a guiding edge to help aid you in this process.
