MDF Molding
MDF molding is one of the most commonly used materials in the building industry today. Here are the basics of MDF molding and what you need to know about it.
Definition
MDF stands for medium-density fiberboard. This material consists of pieces of wood that are pressed together tightly. This material is often used as a substitute for real wood molding. MDF is not as dense as real wood, but it can be made to look exactly like it from the outside. Therefore, once it is installed, most people will not know the difference between MDF molding and real wood.
Cost
One of the main advantages of using MDF molding is that it provides you with a cheaper option than solid wood. When you are trying to build or remodel on a budget, using MDF molding can be a great way to save money.
Durability
When working with MDF, you will need to make sure that you are very careful. It is much more fragile than a solid piece of wood. It can break under pressure if you are not careful. However, once you have installed MDF molding, it should hold up to normal wear and tear.
