Metal Roof Replacement Tips Metal Roof Replacement Tips
Of all of the home improvement projects, roof replacement is the most important one that you may have to undertake. This is because leaving an old or damaged roof will allow the elements such as water, snow debris, insects and rodents to get in your house. You need to attend to a faulty roof immediately, in order to maintain the integrity of your home, and avoid allowing the problem to get worse. When replacing a metal roof, there are some things that you have to keep in mind, to ensure that your project is effective and that your roof is properly installed.
Know the Extent of Damage
It is important to know how much damage your roof has incurred over the years. You need to determine this, so you will know how much time and resources you will need to dedicate to the roof replacement. For example, if your roof has a small hole in 1 of the panels, you don’t need to change everything. Simply change the panel with the hole in it and you’re good to go. This saves you a lot of time and money, because you carefully determined what needed to be done.
Use Energy-Efficient Metal
Using energy-efficient metal can give you a federal tax credit, so consider this when replacing your metal roof. 30 percent of your total cost of your roof replacement may be subsidized. The government grants a maximum of $1,500 dollars in tax credit for the repair of your metal roof, just as long as you use energy-efficient metal. This helps you a lot in your expenses, so be wise and seriously consider this option. You just have to make sure that the material you are using passes the energy-efficiency requirements set by the government.
Canvas Thoroughly
Metal can be quite expensive, so you have to do proper canvassing methods in order to maximize your money. There are a lot of home improvement and hardware stores that give occasional discounts, depending on the amount that you order. They can also be tied to various credit cards, that can give additional benefits. Make sure that you scour through all of the deals, and make an informed decision, before purchasing and placing your order for your roof replacement.
Getting the Proper Support Materials
Once you’ve determined the right material for your metal roof, it’s also important to purchase the proper support materials, in order to keep it in place. You need to get the appropriate fasteners. The correct flashing also has to be purchased, because it is responsible for protecting the joints of your roof from the elements. These support materials are therefore very important in your metal roof replacement.
Protection
Once you’ve replaced your metal roof, make it last by applying the proper protection, such as primer and paint. If you can afford it, get the best anti-rust primer and paint possible, in order to protect your roof from the elements. This protection will make your roof last a long time, and roof replacement may not be necessary for another 15 to 20 years.
