Metal Siding Cost vs Brick Veneer Siding Cost Metal Siding Cost vs Brick Veneer Siding Cost
If you are consider working on your home in the near future, you will want to be sure that you check out both brick veneer as well as the metal siding cost to compare the two. While both of these materials have their advantages, it is important to consider the financial investment involved with each option. Here is a quick guide that can help you the brick veneer and metal siding cost.
Metal Siding
Metal siding has a surprisingly low cost when it comes to both installation up front and maintenance over the years. Depending on the type of metal that you want to use on your home, you can find it as low as $2 per square foot and up to about $15 per square foot. If you are on a budget, you can find something well within your range.
Brick Veneer
Brick veneer is also rather inexpensive to buy upfront, with costs between about $6 and $12 per square foot. While the maintenance is also low for brick veneer, the additional costs for installation may make it slightly more than the metal siding, as you need to deal with adhesive as well.
