Moisture in Carpets
A leak that seems harmless at first can cause significant damage to your carpet. You might have fixed the cause of the leakage right away, but it has already soaked the carpet, and that can result in severe consequences later on. Remember that it's not only your carpet that is exposed to the damage but also the flooring underneath it.
When the carpet gets wet, it might feel damp. This makes it very uncomfortable, and it is essential to learn how to fix it. For that reason, this guide discusses how to dry wet carpets that feel moist. But before that, it is essential to know the signs that show your carpet is moist.
How To Identify a Moist Carpet
A moist carpet isn't always easy to spot like it is the case with identifying a burst pipe. The carpet might seem dry on the surface, meaning you will never know if the moisture has been soaking the inner fibers for long.
You are likely to experience these signs if you don't check the corners of your home that might cause flooding. One of the common signs of a moist carpet is smelling a foul odor from the affected area. After noticing this, you should act right away. The foul smell can leave your home stinking if the affected area is not treated.
Why Does the Carpet Feel Moist
Cleaning and vacuuming your carpet regularly might not fix the problem. If this is the case, it shows that the moisture has seeped through the carpet's inner fibers and affected its stability. As time goes by, you might notice some discoloration in some parts of your carpet.
Letting wet carpets go for a long time without attending to them can cause significant damage not only to the carpet but also to the subfloor and padding. Mildew and mold can grow, resulting in a wide range of problems.
Mold spores can be very toxic to both animals and humans. This means they could cause infections that affect your health. They also affect the air conditioner in your home, triggering allergic reactions.
How To Dry Moist Carpet
After knowing that you have a moist carpet, how do you dry it up. There are several ways you can do so. Some of them include;
Use Vacuum
One way you can soak out moisture from your carpet is by using a wet vacuum. Wet vacuums work excellently to get rid of water and moisture. They are generally cheap, or you can choose to rent one if you intend to use it only once.
Once water saturates the carpet, it means the carpet padding is also moist or soaked. This means you have to replace it to avoid creating an ideal breeding ground for mold. This can be dangerous not only to the carpet but also to your health.
Inspect Fixtures and Furniture
The next thing you should do is check if the moisture has affected your fixtures or furniture. Any damage to furniture might force you to replace them. This is likely to be the case, especially if water has accumulated and caused significant damage to fixtures and furniture. Such a level of damage is severe.
Improve the Airflow
Once you have soaked the moisture out of your carpet, it is vital to keep the ventilation going. You can do that by opening the windows and turning fans on to maximize air circulation. You can also do that to clear musky odors.
You can also use high-power fans or dehumidifiers to help in the drying room. This will help stabilize the conditions. Fans will not only help get rid of the moisture but also the foul odor that makes the room uncomfortable.
Steam Cleaning
This is one of the most reliable ways of drying the carpet. Steaming deodorizes your carpet and helps remove harmful toxins. Steaming involves a high temperature deep clean that cleans the inner carpet fibers.
It also removes dead mold spores that might make it hard to use your carpet. If you have sufficient experience and equipment, you can make steam cleaning a DIY project. Alternatively, you can hire a professional to do it for you.
DIY Carpet Cleaning
There are several ways you can clean your carpet and help get rid of moisture. One reliable way to do so is by using baking soda to absorb moisture. This also helps save your carpet from mold. Start by sprinkling baking soda and letting it sit on your carpet for around half an hour.
Then, vacuum it up to efficiently remove the trapped moisture. Baking soda is preferred for this DIY project because it is the cheapest and most reliable method to dry up your carpet quickly.
Besides, baking soda doesn't pose a significant risk to your health or affect your animals in any way. However, for safety reasons, you should wear protective clothing when using baking soda.
