Old House Siding: Repair or Replace? Old House Siding: Repair or Replace?
If you are wondering whether to repair or replace your old house siding in upgrading your home, you need to consider a lot of things. Replacing it will surely get your house a much needed face lift but it can be expensive. Replacing damaged or broken parts may be more appropriate if you are short on the budget but it may not completely overhaul the appearance of your house. The best thing to do is to consider the condition of your siding first. If the material is still relatively new, there is no need for you to replace it. If certain areas have damages, you can contain the replacements on those areas only. The process would not take much of your time and you do not have to spend a lot on the project.
Repainting Your Old Siding
If your only excuse for replacing your old siding is because you do not like its color, you do not have to install a new material just to change it. Special kinds of paints can be purchased that were specially made for sidings. They adhere properly to vinyl and other siding materials and your house will look just like it just had its siding replaced. This is an economical way of upgrading the appearance of your house without spending thousands of dollars. You can even do the project yourself if you have the time and the materials available.
Aluminum House Siding
If you have an old siding that is made from aluminum installed in your house, you may consider replacing it instead of just a repair. You can also repaint it to have that fresh, new look but the appearance would only be good at a distance. It will not look as good closer and you will be lowering the value of your property. You would decrease the curb appeal of your house as well. With an aluminum siding, it is easy to have dents and such flaws can be seen fast. The metal siding also increases the heat inside your house during the summer months. This is because aluminum traps the heat in instead of allowing it to be vented out.
Increasing the Looks and Value of Your Home
If your intent is to make your house more appealing or to increase its market value, you should also have your siding replaced. The task can easily be done by you with the help of some tools and materials that you can purchase from a local hardware or home improvement outlet. However, if you have never done such a project before, it might be a good idea to have a professional do it, or enlist the help of a family member or friend who knows how.
If you decide to do the replacement or repair of your old house siding, there are some instructions out there that are simple to follow even by a novice. Make sure that you can take measurements accurately or you are going to waste a lot of materials and money. Consider all the options that are available for you first before taking a step, to ensure that you are going to do the right thing.
