Onyx Countertops: Pros and Cons
There are many different reasons why onyx countertops are a popular choice. However, before you make your final decision, you should do some research on why or why not it is the right choice for you. Onyx is used for a lot of different things. It can be used in flooring, and of course on counter tops. Below you can discover soem information on using this material for counter tops. Read the information, and then make your decision if it's the right material for your project.
Variety of Colors
Onyx counter tops are elegant, and can warm a room in an instant. It comes in a variety of colors, and when finished, it gives a sheen and classic look to any kitchen.
Durability
Onyx is a lot like marble in the durability category. It lasts a long time if it is taken care of appropriately. However, it is a bit softer, so therefore, can be scratched pretty easily.
Staining
Onyx does have a tendency to stain pretty easily. There are sealers and protective liquids that can be applied, and if done correctly, it will help in this area, but does not prevent stains from happening.
Onyx is used in a lot of different ways, and it is pretty popular. Before your final decision, weigh out the pros and cons, and then make the decision. Good luck.
