Optimal Angles for a Ceiling Fan Blade
The angle and direction of a ceiling fan blade affects how the air is circulated in your home. Installing a ceiling fan in your home is a good way to improve air circulation and provide a cool breeze in the summer. However, it's important to have your blade set at an optimal angle for efficient air circulation and cooling.
Set the Blades
For a ceiling fan to move the correct amount of air and achieve good circulation, you should set the blades at a 14-degree angle. Blades that are set at a lower angle will slice the air but not create proper air circulation. Blades set at a 20-degree angle meet too much resistance, which may cause the motor to burn out.
The blades of a ceiling fan are very important because they determine the amount of air that gets circulated in a room. Although a 14-degree angle is ideal, you can set the blade bracket to hold the blade between 12 and 15 degrees to get good airflow. Keep in mind that it's also important to ensure your blades are balanced so that the fan does not wobble. Any blade less than 12 degrees will not circulate the air and will be less efficient. The better the angle, the more air circulation you get.
Benefits of Ceiling Fans
Ceiling fans are a great way to improve your decor and the air circulation in your home. Ceiling fans have improved drastically over the past few years to be more efficient and look better. They can cool your house down in the summer and warm it in the winter. In addition, they don't cost a lot to operate and are sold at affordable prices in home improvement stores.
In fact, today's energy efficient ceiling fans have the ability to reduce temperatures in your home by about 7 degrees in the summer. These days ceiling fans are being used in many different areas, including patios, kitchens, and bathrooms.
Ceiling fans come at different prices, however, you can usually find a high quality ceiling fan for a reasonable price. Of course, there are designer ceiling fans that cost thousands of dollars.
Most homeowners can't afford this type of ceiling fan and will do just fine with a standard ceiling fan that is designed to be energy efficient. Stay away from cheaply made ceiling fans, as they have a tendency to bend and warp over time. If your ceiling fan lasts for many years, you will get the money invested back in a very short amount of time.
Shop Around
When shopping for a ceiling fan, make sure you look for a high quality motor, durable material, and a good warranty.
Ceiling fans are most efficient when placed in the right size of room. Do your research ahead of time to find out what fan fits best in your size of room. If you research the choices available it's more likely you'll find a good price on a high quality, durable ceiling fan that will last you for many years.
