Paint On vs Spray On Roof Sealer Paint On vs Spray On Roof Sealer
With the roof being one of the main protective barriers to your home, it can be necessary to apply roof sealer to ensure that the benefit remains. The sealer will act as waterproofing for the roof, which will help it to last longer as well as prevent the ingress of water. Before beginning the process, it is beneficial to be aware of the differences between the applications so you can decide which is best for you.
Tools
The tools required to apply the roof sealer will differ according to the method that you use. When the project is easier to achieve by spraying the sealer onto the surface, you will find that a specialized spraying device will be required. This will often be able to be hired from an equipment hire firm, which will require you to learn how to use it properly. Similarly, it will be necessary to ensure that the tools you use are suitable for use with the sealer.
Application Time
The time in which it takes to apply the roof sealer will differ according to which method of application is used. You will find that the process of spraying the sealer onto the surface of the roof will be quicker than painting it on. Using a sprayer will help you to cover a quicker surface area in a shorter amount of time than a paintbrush or roller. Similarly, you will need to take into account how many coats of sealer are required. In some cases, using a paintbrush or roller will be all that is necessary to apply a sufficiently thick layer. However, you will find that the fine spray produced by a sprayer can mean you need to go over the roof several times when using this method.
Cost
While the cost of the roof sealer will often be similar no matter what method of application is used, you will find that the end cost will differ. This will often come about as a result of the accessories necessary to complete the project. Spraying the sealer on will usually be the more costly of the two methods, whether you purchase or rent the equipment needed for the application process. The cost of the sealer will vary according to the purpose that it will be put to, such as protecting the roofing material or adding to the waterproofing.
Technique
In the event that you do not have experience in spraying roof sealer, you are likely to find that it is easier to be precise by painting the sealer onto the roof. You are likely to find that you can achieve better control with a paintbrush than you would with a sprayer. When using a sprayer, you are more likely to need to cover up any sections of the area that require covering up. It is worthwhile testing the sprayer before using it on the roof to determine the scope of the spray. The manner in which you move across the roof will also vary as a spray will make it easier to access.
