Pellet Stove Hearth Construction Tips
Adding a pellet stove to your living area can be a great source of beauty and warmth and boost the value of your home.  Here are a few tips:
Tip 1 – Placement
The most important thing to think about is the placement of the pellet stove. Safety should be the primary concern so be sure to check with the stove manufacturer as well as the local fire department to get their recommendations.
Tip 2 – Foundation
The foundation of your pellet stoves hearth is vital as this is what will prevent the floor from being ruined, or worse, catching fire. The hearth pad should be something non-combustible, such as cement backer board, Wonderboard, concrete or sheet metal.
Tip 3 – Hearth Material
There are three basic materials to think about for a pellet stove hearth.  Depending on your home décor and the practicality, you may decide on traditional brick, a contemporary tile design or the beauty of natural stone.
Tip 4 – Design and Build
Before you begin to build have your design ready and the appropriate materials purchased. This will save time and headache during actual construction. No matter what you have chosen for design or material, a pellet stove is an efficient heating source.
