Picking Low-E Argon Windows Picking Low-E Argon Windows
Low E-argon windows are an investment in future energy savings. They will make your room more comfortable while saving on heating and cooling costs. If you are building a new home, or are just replacing older windows, you may want to consider using argon windows to save several hundreds of dollars each year. Here’s what you should know.
Understand How They Work
Before you look at making an investment like this, you should look at how they work. An argon window has a thin coating on the window that is made of a reflective metal to reflect the heat (or cold) back in to the house. There is also a space in the window that has a gas like argon in them. This doesn’t affect how the window looks, but will keep the heat indoors during the winter months, and won’t allow cool air to escape in the summer months.
Consider the Climate
The climate you are in will have a lot to do with your choices of low E argon windows. The southern regions will benefit from the cooling advantages of these windows. The northern regions may benefit from not losing heat in the cold winter months.
Check Energy Star Ratings
Energy Star is a program controlled by the government that gives ratings to windows and appliances. The rating will tell you how much you can expect to save. Everything that has been rated by Energy Star will display the rating right on the packaging. Not all argon windows are created the same, so check with the ratings to see which ones are the best for you.
Installing low E argon windows may be a great solution for rising energy costs for your family.
