Planning to Pour a Concrete Sidewalk Planning to Pour a Concrete Sidewalk
When you are pouring a concrete sidewalk there are a lot of things that you will want to consider and plan before you even begin the process. Here are a few things to keep in mind.
Measure and Mark
When you are planning to pour concrete for your sidewalk, you will want to do a lot of measuring and marking before you even begin to mix the concrete. The reason for this is because once you pour that concrete in, you will only have a few minutes to act. So you will want to know what the plan is and where it needs to be poured before beginning. The best thing to do is decide the length, width and height that you want your sidewalk to be. Then you can use spray paint to mark the outline of your sidewalk. Measuring a few times is a great idea just to make sure that you get the right amount of concrete.
Check the Ground
The ground before you pour is going to be one of the most important things to watch out for. You will want to make sure that you are leveling out the soil underneath and if the drainage system isn't great then you can add a level of gravel to soak up any moisture and allow everything to dry nicely.
Choosing Concrete
You want to make sure that you first buy the right kind of concrete that should be used for a sidewalk. Depending on where you live, you will want to go into a hardware store and talk to someone directly about the right type of concrete to buy. The best advice is to ask for five percent of the air entertainment in the mix. This is the best kind to get so that it can handle the expansion due to weather changes. To order the right amount of concrete you can decide the cubic footage and then divide by 27 so that you can convert it into yards. Many professionals say that you want to order an extra five percent than you thought you would need. You can always use concrete for another project later on or even if you have a break in the sidewalk years later, but it can be hard to go out mid-project and then have to mix a new bag.
Mixing the Concrete
You will want to mix the concrete in a wheelbarrow using a shovel. The hardest part is getting the right consistency. Start by adding a little less than the recommended amount of water. Then as you go along you can continue to mix and add water to get the best consistency. You want it to pour easily but not be runny. Mixing concrete is a lot like mixing cake batter.
These tips should help you with the whole process of planning and getting started pouring your concrete sidewalk. Make sure that you take your time and work carefully to ensure that the sidewalk stays level.
