Plastic Window Insulation Tips
Plastic window insulation is a great way to keep your home warm during winter without racking up the bills. Here are a few tips if you are considering plastic window insulation.
Clean the Window
Cleaning the window before you begin applying the plastic insulation is the best way to make sure that the insulation lasts a long time. If you try to attach it with dust or debris on the window, it will most likely slip off in a few days. The best way to clean around the window where you will be pressing the plastic is with rubbing alcohol and water.
Cut More Plastic Than You Need
Cutting an inch or two more then you need is the best way to get a good fit. Once it is secured, then you can cut around the edges.
Use a Hairdryer
Using a hairdryer is the best possible way to get the firmest hold on the plastic insulation. Once you have cut the plastic to the size of the window you can tape around the sides. Then take a hair dryer on the highest heat setting and slowly work your way around the edges to make sure that it is secure.
These tips should help you with the plastic insulation installation, which will help keep your home warm in the winter and cool in the summer.
