Pointers for Building Kitchen Wall Shelves
Building kitchen wall shelves can add to the visual appeal of your entire house. They can also add value to your home. There are different types of wall shelves on the market. You can either build floating wall shelves to display your valuable crockery, or you can build shelves with drawers, to keep your plates and bowls dust-free. Whatever your purpose for building kitchen wall shelves, here are some pointers that can help you to do it properly.
Selecting the Right Design for Your Wall Shelves
This entirely depends on whether you like a traditional design or a contemporary design. It also depends on what style your whole house has, whether it is a cottage house or a modern house. Another thing you need to keep in mind is that the design and color of your new kitchen wall shelves depends on the design of the rest of the kitchen. For example, if you have oak cabinets in your kitchen, you should not build high gloss wall shelves. That sort of combination would not look attractive. It will be better if you use the same material. However, contrasting colors of the same material can look great in a kitchen. If you are not sure what design and color suits your kitchen, you can get ideas from your local kitchen specialists or an interior designer.
Selecting the Right Type of Kitchen Wall Shelves
You can build shelves on either side of your range hood. Add stainless steel or wood towel shelves in your kitchen. You can add S hooks on them and hang your pots and pans, and other kitchen utensils. They can also be used as cup holders. If you do not have a range hood on the wall where you are going to attach the shelves, you can buy long shelves that cover the entire wall from one end to the other. Another way of decorating your kitchen is by using box shelves.
Selecting the Right Material for Your Kitchen Wall Shelves
When it comes to wall shelf materials, you are spoiled for choice. Glass shelves can make your kitchen look more spacious. Wood shelves come in a variety of species. Again, make sure the material suits your entire kitchen décor.
Taking Measurements
The most important factor that determines the final finish of the kitchen wall shelves is its measurement. Always make sure the measurements are exact, because a small variation in the measurements can make a big difference in the final product. After taking measurements, cut the wood to size. If you are building a floating wall shelf, make sure the holes drilled for the shelf are at the same level.
Positioning the Kitchen Wall Shelves
You can position your kitchen wall shelves any way you want. One way to do this is by placing your shelves one on top of the other, all the way up to the ceiling. But, make sure you leave a considerable gap between the shelves. If you want a minimalistic approach, you can add 1 or 2 shelves, on either side of the range hood, and leave the rest of the space open. Your imagination is the only limitation you have, when it comes to building kitchen wall shelves.
