Pool Deck Plans for the Wealthy Pool Deck Plans for the Wealthy
When choosing particular pool deck plans, people are usually limited by the budget that they have for the construction. However, if money is not a problem, you can have an unlimited choice of pool decks that are suited to the kind of pool that you have and the shape that it has been made. A different design is needed for pools that are constructed above ground and for those that were built in the ground. There are also pools that also have a hot tub attached or located beside them. If such is the case, there will have to be some modifications that need to be made on the pool deck plan.
Working with a Builder
If you will be working with a builder to construct your pool deck, you must ensure that some important things are addressed in order to prevent problems later. When choosing for a particular plan, always stake out the area for the deck first. The main reason for this is to find out if the planned deck will be able to accommodate all the pool furniture that you will have, as well as other items that you will need beside the pool. Once the area has been staked out, you can arrange all the furniture and things inside the area and find out how your proposed deck will function. Often this step allows people to know what modifications to do in order to make the pool deck more functional.
Complying with Zoning Requirements in Your Locality
When choosing a particular deck plan for your pool, you should also make sure that you are complying with what is mandated in your local zoning requirements. These should be for the city and neighborhood where you are living. Such a step will prevent any future issues that may come out once you have started with the construction.
Considering Nearby Installations
No matter what type of pool deck plan you choose, you should always consider any installations that may exist nearby. These include wires, pipes and cables which might have previously been installed by local utility companies. Failure to consider such installations may cause you to accidentally damage them and bring you trouble.
Shades Considerations
Building a pool deck should also consider the shades that are needed for it. If the installation will be done on the southern side of your property and there is no shade that can be had from bushes or trees, you should then have a part of the deck covered, so that people who will be using it will have some shades whenever they want during the course of a hot day.
Deck Materials
When you have all the resources that you will need at your disposal, there is virtually no limit on the kind of material that you can use. Materials range from natural wood to composite materials that come in various colors. Before going further with the construction, decide first whether you want a wood deck or not. Learn about all the other materials that are available so that you can make a well informed decision.
