Poured Concrete Foundations vs Wood Foundations
A foundation outside.
Concrete foundations have remained highly popular in home installations throughout the years. As a homeowner, you may find yourself somewhat overwhelmed when it comes to choosing a suitable foundation. Careful thought and consideration should go into selection. The material you choose for the foundation can add or detract from your home value. Functionality is affected by your choice. Below is a comparison between concrete and wood foundations.
Pros of Poured Concrete Foundations
Concrete is much cheaper to install than wood. Poured concrete provides the highest level of strength for foundations. A solid and strong foundation goes a long way in building a stable house because concrete is a highly durable material for foundational purposes.
Once installed, it will last you decades. Some homes with concrete foundations have been standing for well over a century. It is unlikely that you would need to replace a concrete foundation unless you desire a change.
Concrete is a cost-effective material to use for foundations. Both water and fire have no damaging effects on concrete. In the event that an accidental fire occurs, you can be sure your house will be better protected with a concrete base.
Should a leak sprout, especially in the basement, a concrete foundation helps check the damage. Poured concrete is also termite resistant, unlike wood. Termites cause a nightmare for homeowners by destroying the foundation, especially wooden ones.
Cons
Cracking may occur, especially if the concrete is not prepared properly. Cracks necessitate repairs, adding to your home improvement cost. Leaks are caused by both precipitation and groundwater. They are often a challenge to trace. You will have to dig up the entire concrete to identify the source of leakage.
Pros of Wood Foundations
Wood is easier to install than concrete. It also takes less time to install than concrete. Wood gives you easier access to repairs. Wiring and plumbing repairs with a wood foundation are much easier than with concrete foundations. It creates a natural and warm ambiance for the house. It also creates a much warmer basement which requires less heating and cooling, reducing your energy consumption and costs.
Cons
Wood is more susceptible to termite attacks than concrete. It causes endless frustration and expenses as you constantly manage the problem. Treated wood is available, but its quality varies and is uncertain. Sub-standard treatments will simply create more trouble. If you use wood that has not dried well, the residual moisture can cause problems for you. Insect attacks, especially termites, is likely. Rot, growth, and fungus are also encouraged by moist wood.
