Precautions to Take before Walking on Metal Roofing
Safety harness
Ladder
Plywood (2 feet X 4 feet)
Metal roofing can be very dangerous to walk on for a couple of reasons. Not only can metal  become slippery when wet , it can also be subjected to damage if you step on the wrong place. It is necessary to take know what precautions to take before walking on metal roofing in order to protect yourself and your roof.
Step 1 – Strap In
In order to make sure you do not get hurt by falling off the roof, you need to be wearing a roof safety harness. The harness can either be attached to a specific part of the roof, or if the home is really small, it can be attached to the ground on the other side.
Step 2 – Practice Roof Safety
Part of practicing roof safety when walking on a metal roof is to make sure you are not walking on moss patches, in between joists, or on a wet incline. You will either slip, or cause a break in the seam.
Step 3 – Use a  Board
In order to guarantee safety, use a 2 x 4 piece of plywood in order to stand on. The long side of the board should rest sideways against the joists. This will give you a safer surface to walk on as well as spread your weight across several joists in order to protect the roof.
