Pros and Cons of a Concrete Sink
You will find that there are a lot of different reasons why one should get a concrete sink. There are also a few things that you should keep in mind to make sure that a concrete sink is right for you. Make sure that you understand not only the pros but the cons as well when it comes to getting a concrete sink. The more that you understand about what it has to offer, the better off you will be when it comes to deciding if it is something that is right for you.
Unique
You will find that whenever you are looking for something that is different and one of a kind, a concrete sink is something that you should definitely look into. It is difficult to be able to find a concrete sink that will not need to be almost completely customized. This is something that will completely ensure that your sink is made specifically for you. It will be very difficult to be able to find another concrete sink like the one that you have.
Sturdy
You will find that a concrete sink is something that is typically part of a concrete countertop. Not only is this a very attractive and smooth look, it is also incredibly durable. You will find that concrete is of course a very strong and sturdy surface. This is of course no different when it comes to your sink. You will have plenty of years automatically guaranteed to you whenever you have a concrete sink as they are very difficult to damage. It is common that your sink will be made to integrate right into your counter. This will allow for a smooth transition and a beautiful look.
Maintenance
A downside to concrete sinks is the fact that they will occasionally need to be sealed. Cracks and chips will end up happening and you will need to get them taken care of as soon as possible so that they do not have the opportunity to get any worse. This is something that is not very difficult but is something that is absolutely necessary. Make sure that you are able to set time aside to do this task as soon as you see any chips or cracks with your concrete sink.
Installation
Installation is something that you are going to have issues with whenever you have a concrete sink. Obviously, a concrete sink is something that is incredibly heavy. This means that special support will be needed so that you can get it in. You will need to have additional support installed underneath your sink. It is also important that your floor is strong enough to support this extra weight. Something else that you will need to keep in mind when it comes to installing a concrete sink is that they do not come cheap. While a pro is the fact that they are all custom made so they are unique, this is also a con. You will find that this custom made look is something that can be quite expensive.
