Pros and Cons of a Concrete Tile Roof
If you are considering installing a concrete tile roof, there are a number of different things that you need to think about. Concrete tile presents you with a number of benefits and drawbacks. Read on for some of the pros and cons associated with concrete tile roofs.
Durability
One of the main benefits of using concrete tile for your roof is the durability that it provides. Concrete is very hard and can withstand quite a bit without being damaged. Unlike other roofing materials, it should not be significantly damaged by wind or hail.
Cost
Another advantage of using concrete tile is that it is less expensive than other types of tile. Compared to slate, for example, you should be able to save some money with concrete.
Weight
One of the major disadvantages of using concrete tile on your roof is that it weighs so much. Concrete is very heavy, so you must make sure that the structure of your house can support it. Otherwise, you may be looking at serious problems.
Requires Sealant
Another disadvantage of using concrete tile for a roof is that it needs to be sealed in order to work properly. Concrete is very porous and you need to make sure that it remains sealed in order to prevent moisture from coming down through it.
