Pros and Cons of a Neon Car Light Pros and Cons of a Neon Car Light
If you want to improve the appearance of your car, or give it a makeover, consider installing a set of neon car light fittings. These are very popular, as they give the car a distinctive glow that makes it stand out from the rest of the herd. There are many reasons why you might consider getting neon car light sets, although there are also some drawbacks you should consider before you buy them.
Pros of a Neon Car Light
One of the biggest advantages of the neon car light is its flexibility. You can put the neon light wherever you want. You can have them in the front of the car, to add more light along dark roads, or you could add them to the wheel trim, or even inside the car, so that you can see what you are doing both inside and outside.
Cons of the Neon Light
At the back of the car, neon car light systems can interfere with your driving, as the light will glow onto the back window, and glare from this could make it difficult to use your rear view mirror. They also require a lot of maintenance, involving regular cleaning in order to ensure that they illuminate properly.
