Pros and Cons of Brick Siding Your Home With Calcium Silicate Brick
When considering brick siding your home with calcium silicate brick, there are several things to know which may an impact your final decision. Calcium silicate bricks are comprised of lime, quartz, siliceous rock and colorants. These bricks are very accurate in size and shape, but also have very sharp edges that require delicate care.
Cons of Calcium Silicate Bricks
Calcium silicate brick is very moldable and shapeable due to the nature of its ingredients. Because of its unique ingredients, this type of brick is popular when desiring a variation in size or shape of bricks. This allows homeowners and builders to custom order brick size. Also, this brick type accepts color pigment very well, allowing for more personalization in the bricks. In addition, the processing time to create these bricks is drastically lower than other types of bricks. This lowers the production cost of these bricks, making them a great option for builders to use.
Calcium silicate bricks are commonly known to shrink in size due to the nature of its ingredients. Because of this, these bricks must be well installed and mortared to prevent unnecessary cracks and brick movement. Another con to using calcium silicate bricks is that the materials used to create this type of brick is slightly more expensive than that of concrete bricks.
