Pros and Cons of Building a Lattice Panel Deck Fence
A lattice panel deck fence is an easy way of creating a quick solution to enclosing your deck. It can also enhance the visual appearance of your home.
Pros of Building a Lattice Panel Deck Fence
One of the pros is that you can immediately make your space private. It can keep out animals and intruders. It creates airiness while still keeping out direct wind and sunlight. It allows sunlight to filter through. The trellis can be covered in lovely sweet smelling roses or evening primrose which will be well-suited for balmy evenings on your deck. This type of fence is also easy to install and not as expensive as other material.
Depending on the height of your fence, one of the cons could be that you may want to have a view from your deck and your trellis might obscure the view. If it is too low, it can become less of a protection against the weather. Flowers and other creepers can create quite a mess if you use plants which shed their leaves. This can spoil the visual appearance of your home. If you cannot do it yourself, it can become an expensive exercise.
