Pros and Cons of Butcher Block Countertops Pros and Cons of Butcher Block Countertops
Butcher block countertops are a very popular option in homes across the country. Here are some of the pros and cons that you can expect to deal with when you install butcher block countertops.
Pros
One of the biggest advantages of the butcher block countertop is the look that it provides. Nothing else looks quite like a butcher block countertop. This is a look that is sought after in many high-end homes and many people prefer it.
Another advantage of using a butcher block countertop is that you can easily prepare food right on the countertop. You will not necessarily have to worry about using a cutting board to chop food.
Cons
One of the disadvantages of using a butcher block countertop is that it is relatively expensive. In order to get a true butcher block countertop, you are going to have to spend more money than you would with other types of countertop materials.
Another disadvantage of this type of countertop is that it requires more care than other types of countertops. Since you are going to be preparing food on it regularly, you have to make sure that you seal it and you might have to refinish it occasionally whenever it starts to look worn.
