Pros and Cons of Corrugated Roofing
As more people strive to become more eco-friendly and cost-efficient, corrugated roofing has become a viable roofing alternative to traditional shingles for many homeowners. Whether you are building a new home or looking to replace the curling asphalt shingles on your roof, there are a number of reasons to consider corrugated roofing to protect your home from the elements.
Installation
Most roofing jobs usually involve a series of back-breaking steps that help make your roof watertight. Installing corrugated metal roofing is easier and faster than roofing with asphalt shingles. Depending on the style of corrugated roofing you choose, sheets of roofing material will cover a larger area to get the job done in less time. Since corrugated roofing works in a similar way to siding, each installed piece will help guide the next sheet into place to reduce the time you would normally take to make sure each individual shingle is properly lined up. By using pre-drilled holes, you can quickly attach a sheet of corrugated roofing into place and move on to the next piece.
Durability
While most asphalt shingles will need to be replaced every 20 to 25 years, corrugated roofing can be a lifetime investment. As well as being better suited to deal with any climate, corrugated roofing doesn't deteriorate as quickly and can maintain its appearance for many years. With the pressure on to make as many homes as environmentally friendly as possible, the permanent nature of corrugated roofing provides an excellent option over alternatives that will eventually find their way into landfill sites.
Style
Many homeowner disregard corrugated roofing because of the lack of choice in style. However, the days when corrugated roofing was strictly reserved gardens shed are some way behind us and corrugated roofing no longer comes in standard wavy sheet metal or translucent plastic form. By using new technologies, corrugated roofing is produced in a wide range of colors and styles. Depending on the overall look you want for your home, your roof can house the red terracotta tiles of the Mediterranean or the beautiful copper patina of the Paris skyline. You can also find corrugated roofing that looks similar to traditional shingles in sleek black or a muted brown.
Cost
Unfortunately, many DIY enthusiasts can be dissuaded by the cost of a corrugated roofing project. At first glance, prices will be much more expensive than the traditional option of asphalt shingles. However, it helps to remember what you are paying for and a corrugated roof will often last a lifetime and beyond. When you figure in the cost of replacing traditional shingles in the future, it can often be more cost-effective to install corrugated roofing.
Greener Solution
It is the fact that corrugated roofing can be a lifetime investment that makes it an attractive option for homeowners who are looking for ways to shrink their carbon footprint. Like most “green” building materials, you will pay a little bit more initially, but your investment will pay off in the long run.
