Pros and Cons of Foam Roofing
Foam roofing is a newer material that can provide you with a few benefits as well as some drawbacks. Read on to learn about some of the pros and cons of this type of roofing.
Pros
One of the biggest advantages of foam roofing is that it is lightweight and easy to install. To apply, you will simply spray it onto the surface of the roof. This is much easier than handling heavy shingles or tiles and adhesive.
Another advantage of this type of roofing material is that it is very durable. You can get expect to get at least 30 years out of foam roofing without any issues.
Cons
Although this type of roofing is relatively easy to install, it is little bit more expensive than using some of alternatives, like asphalt shingles. Therefore, you will have to come up with a larger initial investment.
Foam roofing is not the strongest material that is available either. If you have a lot of squirrels or birds walking around on it, this can damage the foam. This could lead to the foam coming off of the roof in certain places and causing leaks.
