Pros and Cons of PVC Decking
PVC decking is a common exterior installation in many homes. It is a type of elevated floor that is usually attached to the main house. The floor is made from polyvinyl chloride (PVC), a special type of plastic resin widely used in the manufacture of various products. A well constructed deck makes an attractive addition to your home. It provides an ideal play and recreational area for family and guests. However, the right deck material is a determinant in how functional your deck will be. You may want to consider PVC for your decking needs. It helps if you know the pros and cons.
Flexibility in Design Options
You can use PVC to construct decking of various sizes, shapes and styles. Whether you want a single platform deck or multi-level design, PVC allows you to do this. This material is available in various surface textures and a virtually unlimited color selection. It can also be produced to resemble wood. With all these options, it makes it easier to accomplish your particular home décor.
Affordable
PVC is one of the most affordable decking materials available on the market. You needn’t strain financially when you decide to install a deck of this material.
Ease of Installation
The decking can be installed easily and quickly. Minimal effort and time is required to install. The lightweight nature of vinyl makes installation easier. This contributes towards a quick turnaround which makes PVC a smart choice for deck construction.
Durable
A PVC deck has a long life partly because of its weather-resistant properties. It is moisture resistant, bug resistant and rot resistant. Unlike wooden decks which are susceptible to bug attacks and rot, a PVC deck gives you peace of mind. It does not easily splinter or peel. It also doesn't develop scratches easily.
Low Maintenance
The low maintenance requirements of PVC make it an ideal material for decking purposes. You don’t have to stain, paint or apply special treatments to protect the material and maintain it in good condition. PVC doesn’t develop stains. It is also easy to clean when necessary. Simply hose down the deck and allow it to dry.
Eco-Friendly
As for green considerations, PVC rates highly since it is 100 percent recyclable. PVC for decking does not add more demand on the exploitation of environmental resources, some of which are already in danger of depletion.
Increases Aesthetic Appeal
Finally, a well constructed, colorful PVC deck adds value to your lifestyle. You also get excellent dimensional stability with PVC. This adds to the functionality of the deck. It increases the aesthetic appeal of your exterior décor, which adds value to your home.
However, PVC decking isn't without its disadvantages.
UV Damage
Although PVC doesn’t fade easily, prolonged exposure to UV rays ultimately causes it to fade. The decking also becomes brittle and more susceptible to cracks.
Difficult to Repair
Unfortunately, it isn’t easy to repair a PVC deck. If a section gets damaged, you’ll be compelled to replace the entire deck. This adds to your home improvement costs.
