Pros and Cons of Using Vinyl Adhesive Spray for a Corner Bead
When deciding which type of corner bead to use, you want to consider both the pros and cons. Here are a few things to keep in mind when you are choosing vinyl adhesive spray for a corner bead.
Cost and Availability
The vinyl adhesive spray comes at a great cost, especially compared to several other types of adhesive. You can find this spray at several different types of home stores as well as even a grocery store.
Efficiency
This spray is great because not only does it hold well and work great for the project, but it is really easy to use. All you have to do is point at the section you need to spray and then hold down the spray button. It is so easy, anyone can do it.
Environmental Factors
The downside to this type of adhesive when it comes to corner beads, is the damage that is done to the environment. While the damage is disputable, some say more than others, there is not argument that there is some damage done and for those that are particularly worried about their green footprint, there may be other ways to tackle this project.
You will want to weigh these pros and cons when deciding how you want to move forward with your next project.
