Protect Your Truck Paint: Rusted Metal on a Truck Protect Your Truck Paint: Rusted Metal on a Truck
One of the most visually unappealing sight on truck paint is rusted metal. It is much easier to prevent rust from developing on your truck than it is to remove it once it sets in. In fact, trying to remove rust from a truck can often prove to be nearly impossible. Therefore, it is important that you understand how to combat and prevent rust before it ever happens.
Prevent Rust from the Start
Your preventative maintenance against rust on your truck should start the day you buy the vehicle. Whether you are purchasing a new or used vehicle, you should have some sort of rust preventative solution applied to the undercarriage of the vehicle. Many car dealerships will provide this service for you for a charge. However, there are many chemical solutions that you can purchase from your local auto parts store or order online that will do the job just as well. Also, if you choose to do the work yourself, you'll probably save several hundred dollars in the process.
Keep Your Truck Cleaned and Waxed
One of the most effective ways of fighting rust and corrosion on your truck is to keep it clean and waxed. Make sure that you wash your truck every couple of weeks or so to remove salt, grime and other chemicals that may build up on the surface of your vehicle. Over time, the presence of these contaminants can aid in the development of rust on the body and undercarriage of your truck.
The painted surface of your truck is constantly under attack from the elements. Therefore, you should use a quality car wax to to protect the painted surface of your vehicle. Wax not only makes a truck look better, it also helps to seal and protect the paint. Because the paint is your car body's only real defense against rust and corrosion, you should protect the painted surface as well.
Don't Forget the Undercarriage
When washing your vehicle, don't forget the undercarriage. Many people often neglect to properly wash and clean the undercarriage of their trucks. This can lead to corrosion or rust damage as well. This is especially true if you live in areas that experience snowfall in the winter. In many areas, salt and other chemicals are used to melt the ice and snow on roads and highways.
The salt and chemicals used to melt the ice and snow can wreak havoc on the undercarriage iron and metal used in a truck, so make sure to spray and clean the undercarriage of your truck with a high-pressure water hose and nozzle after a heavy snow when salt or other chemicals are used to melt the ice on the roads.
Repair Dents or Scratches Immediately
If you notice dents on your truck or scratches in the paint, you should have them repaired immediately. Scratches or chips in your truck's paint will quickly lead to rust and corrosion. Even if you're not able to get a dent repaired, you should purchase a touch up paint kit for your vehicle and fill in any scratches and chips in the paint. This will help to prevent water and moisture from getting in between the paint and the bare metal of the vehicle.
