Proximity Locks: Features and Uses
if you are interested in upgrading your security, you may want to consider installing proximity locks. These advanced locks have many advantages over ordinary mechanical locks, while giving you the secure doors you are accustomed to. Installing a proximity lock on a door gives you a great deal of control over who has access to it, and gives you a great deal more flexibility than a traditional lock. A proximity lock relies on the same fundamental systems as a traditional lock, and includes many redundant backups that will prevent you from being locked out of your property. What follows should help you to understand the various features of proximity locks.
Traditional Backup Systems
While you might not think of a traditional lock as an upgrade that you should be aware of, especially when you are upgrading to the most current security system, it is definitely something to consider as a benefit. The truth is that even the most advanced lock can break or malfunction. When this happens, it is a good idea to have a temporary solution on hand so that you do not need to lose access to one of your doors, or break into your own property. The physical backup key, which requires no electronics and works exactly like an ordinary key, is a great way to do this. Fortunately, almost all proximity locks will include one.
Multiple Keys
Proximity locks include the capability to accept multiple keys. If you are trying to restrict access to an area to a certain select group of people, this can save you a lot of trouble.
Additionally, programming which users are allowed access to a door from a central location can make your work a lot easier in certain situations. For many security situations, it can be very convenient to be able to instantly block off the access of a person who no longer needs access, or give a person a key without having to make a copy. By using blank, replaceable key cards, you can save yourself time, effort, and money, while keeping the strength of your security at its highest.
Independent Power Supply
Proximity locks use their own power supply. Usually this will come in the form of ordinary batteries that can be replaced easily. Luckily, these batteries tend to last for a very long time. Additionally, as they are separate from the electrical grid, they are completely reliable. In the event that the proximity lock loses power, the traditional backup system remains usable, and can be used to access the door and replace the batteries. Because of the way in which proximity locks are powered, they do not lose power even in the event of a power outage.
Keypad
Many proximity locks include a keypad that can be used to enter a key code. This can be a good backup system in the event of a person losing their key card. Additionally, if a key card becomes damaged, the key code can be used until a replacement card becomes available. Because of backup systems like this, proximity locks are very reliable.
