Quarry Tile Floor: Pros and Cons
If you are considering installing a quarry tile floor, there are many different factors that you should look at. This type of floor can provide you with some advantages and disadvantages to be aware of. Here are some of the pros and cons of quarry tile floors.
Pros
One of the biggest advantages of this type of tile is that it is very inexpensive. Quarry tile is very basic and does not require any glaze on the top layer of the tile. This makes it fast and easy for tile manufacturers to produce which lowers the cost to the consumer.
Another advantage of this type of tile is that it is very durable. Quarry tile tends to be very thick and will not chip or break easily. This makes it an ideal solution in heavy traffic areas.
Cons
One of the disadvantages of quarry tile is that it is notorious for being stained. Since there is no glaze on the top of the tile, liquids can easily penetrate the tile and permanently stain it. Therefore, even though it is a durable solution, it might look bad after a very short period of time.
Installation of quarry tile is also more difficult because you will typically want to try and seal the top layer to help avoid problems.
