Quarter Sawn Lumber vs. Plain Sawn Lumber Quarter Sawn Lumber vs. Plain Sawn Lumber
You may have often wondered why the prices of quarter sawn lumber are higher than plain sawn lumber, because there is a major difference. What you use totally depends on your taste, the project that you are using it for and above all your budget.
Basic Difference
The main difference between quarter sawn lumber and plain sawn lumber is the way they are sawed from the log. The sawing technique brings about the difference in the appearance, properties and the use of the lumber.
Plain Saw Lumber
This is the commonest form of lumber because you can saw this lumber fast and it creates less waste. It is also the simplest way that you can saw logs into boards. For example, it is possible to cut 18 inch diameter logs in as little time as 45 seconds. This system has great commercial value because it is production efficient.
Quarter Sawn Lumber
The most famous quarter sawn lumber is from oak. Other species too show a unique appearance when quarter sawn. For many furniture craftsmen the ray flecks that are revealed when a log is quarter sawn give it a unique appearance.
This lumber is mainly more expensive than plain lumber simply because it takes longer to saw a log and produce less board footage. In the bargain more waste is created, and the company obviously charges you for making up for the lost production. Also, a true craftsman is ready to pay more for this kind of lumber simply because it has character and unique properties.
