Queen Captain's Bed Building Tips
A captain's bed is a type of bed that sits on top of a set of drawers, and a queen captain's bed could be a great addition to any bedroom with enough space for one. Captain's beds are one of the most difficult types of beds to build yourself, but they're very rewarding if you're up to the task of making your own. The following list of tips will help to direct you in the process of designing and building a queen captain's bed at home.
Tip 1: Plan Ahead
Before you even start, use a tape measure to take the dimensions of the room you want your captain's bed to be in to see where it will best fit. A queen-sized bed is 60 inches wide and 80 inches long. Think carefully about where you want it and what you want it to look like. Make sketches of your ideas to have a better idea of which ones will work best, and select your favorite. Before you go out to buy wood, make a more detailed sketch of this final idea and include measurements for each part that will be included in it.
Tip 2: Don't Make Long Drawers
Because you will have a bed on top of the drawers in the bottom part of your captain's bed, there will be a lot of weight pressing against the frame for the drawers. Over time, if the drawers aren't supported well enough, this could cause the wood to warp slightly, making the drawers not fit quite right in their frames. This would make them stick in the frame and it would be difficult to pull them in and out. To prevent the wood in the drawer frame from warping because of the repeated pressure of people sleeping on it, make many small drawers instead of a few big drawers. This will give the drawer frame more support.
Tip 3: Finish Wood Before Building
It is much more convenient to finish the wood before it has been constructed into the bed frame. This is because you will have to apply varnish with a paintbrush, and it will be far easier to spread an even layer of varnish over a series of flat boards than a captain's bed with a complex shape covered in crevices and holes.
Tip 4: Use Pilot Holes
Throughout the process of building a captain's bed, you will be working with relatively thin pieces of wood. Whenever you screw thin pieces of wood together, there is a good chance of the wood splitting, so it is a good idea to drill a pilot hole before you put in each screw.
If you can't seem to find enough space in your room for all your things, you may want to consider building a queen-sized captain's bed. Many people who own a captain's bed keep their clothes in the drawers underneath their bed, freeing up closet and cabinet space for other things. Although a queen-sized captain's bed will take up a lot of space in your room, the drawers underneath it will more than make up for the loss of floorspace.
