Radiant Ceiling Heat Pros and Cons
If you are considering installing radiant ceiling heat in your house, there are a number of things that you should think about before you do. Here are some of the pros and cons of radiant ceiling heat.
Pros
One of the big advantages of radiant ceiling heat is that it will not dry out the air in your house like a forced air system does. Instead, it will not negatively affect the level of moisture in the air.
Another advantage of this type of system is that it produces very consistent and comfortable heat. You will feel heat emanating down from the ceiling. This type of system is also quieter than using a traditional forced air heating system.
Cons
One of the disadvantages of this system is that it is fairly expensive to have installed. It is not the most common heating system, and therefore you might have trouble getting a very competitive price on it.
Another problem with this type of heating system is that it can be difficult to repair. If something breaks, it will require someone going up into the attic and making the necessary repairs on the system.
