Reasons to Choose an Aluminum Roof over Other Metals
An aluminum roof has fast become the roofing material of choice for many people. There has been a steady shift from using traditional materials like asphalt as more and more people have come to learn of the benefits that metal roofing provides. Steel, aluminum, copper and tin are some of the common metals that have been used for roofing purposes. However, aluminum has quickly gained a reputation as one of the most ideal materials when it comes to metal roofing. Following are some reasons that make aluminum an excellent choice for roofing needs.
Reflector Properties
Aluminum is an excellent reflector of heat. During the summer, aluminum metal roofing can reflect more than 90 percent of the sun's rays. This has the result of making the house cooler despite the high temperatures outside. In the winter, aluminum roofing reflects heat back into the house, thus creating warmer temperatures inside. Since the roof is the major conduit through which most heat is lost from a house as well as transferred outside, having an aluminum roof can effectively help in regulating temperatures in the house. Other metal roofing materials such as copper, tin and steel retain heat which has the effect of causing high temperatures indoors especially during hot weather. However, aluminum is a radiant heat barrier and deflects heat, causing your house to become cooler. You can enjoy having the house cooler during the summer and warmer in the winters if you install an aluminum roof.
Energy Saving
Aluminium has unique heat regulating properties unlike steel, copper or tin. Since aluminum roofing works to keep your house cooler during the summer and warmer in the winters, you will use considerably less air conditioning. This translates to less energy consumption and will help reduce your power costs.
Durability
Aluminium shingles have a long life span. They literally last years without showing much wear and tear. They stand up well to weather extremities yet will retain their new and shiny look. If you live in area of high humidity or experience acid rain, it is best to select aluminum for your roofing needs. Aluminium does not warp, crack or rust. Steel, tin and copper, if not galvanized are subject to corrosion and rusting. You can add value to your home by selecting aluminium roofing as it will last years while retaining its attractiveness as the condition of the roof is a vital factor in home valuation.
Versatility
Aluminum is malleable and available in various roofing types and designs. This gives you greater flexibility and choice when it comes to deciding on your roofing needs. You can get aluminium roofing in shingles, tiles, shakes, panels or standing seams.
Lightweight
Unlike steel or copper which are heavier metal material, aluminum is light. This makes it easy to work with, transport and install. You use less labor when installing an aluminium roof which saves on labor costs.
Environmental Friendly
Aluminum roofing consists of as much as 90 percent of recycled matter, which makes it an environmentally sound material to use in building. This makes it a good choice especially with all the environmental concerns surrounding us these days.
