Recessed Step Deck Lights: Safety After Dark Recessed Step Deck Lights: Safety After Dark
Recessed deck lights are an increasingly popular lighting option for most homes. The attractive setting and mood created by these lights is perfect for those seeking to turn their home into a beautiful space both inside and out, and the benefit of added safety also contributes to the safety of these lights. Deck lights can be extremely useful in illuminating dark corners of the patio or the stairs leading up to the main house- thus decreasing the risk of accidents. Hence, deck lights are not only an aesthetic, but also a practical safety, fixture to add to the house.
Why Recessed Deck Lights Are a Good Option
Recessed deck lights are a great way to add a touch of elegance and style in your home while making it safer as well. These lights can be installed in staircases, casting a soft but visible glow to the area, which can serve as lighting at night, specially for the elderly. Built into the wall or the post, they are out of the way and don't become a hazard in the presence of children. These deck lights also reduce glare and provide subtle lighting without interfering with the atmosphere or mood of the setting.
Some types of deck lights are also available with LED's which not only supply the same amount of illumination, but last longer and are up to 80% more power efficient than conventional bulbs.
Varieties of Deck Lights Available in the Markets
You can choose from an exciting range of deck lights available in the market to find one that best suits your needs and your tastes. There are a number of styles, shapes and sizes of recessed deck lights available and you can review them all to find one that looks beautiful while also serving the safety needs of lighting up your house and its surroundings. The varieties can meet the needs of different kinds of outdoor staircases and varying styles of decks. Since the external façade and landscape of each house is different, you will have no trouble in finding a style that is best suited for your needs.
Many people choose to go in for the conventional pole light, which casts a bright glow in a wide radius around itself. Pole lights are usually affixed on top of tall posts that can either be placed right at the foot of the deck stairs, or you can choose to have smaller posts positioned alternately on the staircases so that you have ample lighting in the region. For those who want a dim yet safe lighting system, there is always the option of having recessed deck lights fixed in the walls of the deck. These lights are usually designed to resemble small lamps and have great aesthetic appeal and can add a quaint touch to the appearance of the house.
Flood lights in miniature sizes are also very popular, as they can help light up the stairs without overpowering the appearance of the entrance. Since these deck lights have to be fitted into the staircase, they require extensive electrical wiring and usually require a professional to come and install them.
