Red Oak vs White Oak Floors Red Oak vs White Oak Floors
If you're currently trying to decide between red oak or white oak floors for a certain area of your home, it's important to be aware of the benefits offered by both types of flooring. While both varieties of oak flooring are very resilient, there are several key differences that separate the two.
White Oak Flooring
When making your decision, one thing to keep in mind is the extreme firmness and durability synonymous with white oak floors. Because of the aforementioned traits, this type of flooring is quite resistant to scoffs, scratches, mold, mildew and assorted varieties of everyday wear-and-tear. However, while they are decidedly harder and more resistant to the elements than their red oak counterparts, white oak floors can be a bit pricier. Although if your home's floors typically undergo a fair amount of punishment or if you're looking to add flooring to an outdoor porch or deck, the additional expense may prove to be worth the added degree of protection.
Red Oak Flooring
Despite not being as durable as white oak flooring, red oak floors can make a great addition to virtually any part of your home and are an affordable, effective substitute for their white oak counterparts. Like white oak floors, they are able to stand up to scoffs and scratches fairly well, although they are not as resistant to moisture buildup and, by extension, the formation of mold and/or mildew. Whereas white oak flooring is recommended for furnishing both indoor and outdoors areas, red oak flooring should only be used indoors.
