Refrigerator Freon Removal Guide
man working on the back of a refrigerator
  • 4-8 hours
  • Advanced
  • 600-6,000
Sight glass
Recovery system
Recovery cylinder
Tubes
Sight glass
Recovery system
Recovery cylinder
Tubes
Are you actually dealing with freon or another gas? Is it even legal to remove freon yourself? Why would you want to in the first place? We have the answers to these questions and more in our refrigerator freon removal guide outlined below.
What Freon Is and How It Works
Freon is a brand name for a group of refrigerant gasses that were widely used in refrigeration and air conditioning systems. The term "Freon" is often used generically to refer to these types of refrigerants.
Freon plays a crucial role in the cooling process of a refrigerator. It works on the principle of phase change and heat transfer.
To simply explain the process, we start with compression. The refrigeration cycle begins with a compressor, which compresses the gaseous refrigerant, increasing its pressure and temperature.
The compressor creates a high-pressure region for the refrigerant.
The high-pressure refrigerant then flows into the condenser coils located on the back or bottom of the refrigerator. As the hot refrigerant passes through these coils, it loses heat to the surrounding air, causing it to condense into a high-pressure liquid.
After that, the high-pressure liquid refrigerant passes through an expansion valve or capillary tube, which creates a pressure drop.
This sudden drop in pressure causes the refrigerant to expand and evaporate, absorbing heat from its surroundings.
The now low-pressure refrigerant enters the evaporator coils located inside the refrigerator. As it evaporates, it draws heat from the air inside the refrigerator, thereby cooling it. This process cools the interior of the refrigerator.
The evaporated refrigerant, now in a gaseous state, is drawn back into the compressor to start the cycle again. The process continues in a closed-loop system, with the refrigerant continuously circulating between the compressor, condenser, expansion valve, and evaporator.
The purpose of Freon or refrigerant in a refrigerator is to facilitate the transfer of heat, allowing for the cooling of the interior space.
By absorbing heat from the refrigerator's contents and expelling it outside through the condenser coils, it helps maintain a lower temperature inside the fridge.
It's important to note that newer refrigerators may use different types of refrigerants due to environmental concerns and regulations.
For example, hydrofluorocarbons (HFCs) are commonly used as a more environmentally friendly alternative to older refrigerants like chlorofluorocarbons (CFCs) and hydrochlorofluorocarbons (HCFCs).
Reasons to Remove Freon from a Refrigerator
There are several reasons why it may be necessary to remove Freon from a refrigerator.
man repairing refrigerator
Repair or Maintenance
If a refrigerator has a refrigerant leak or a malfunctioning component, it may be necessary to remove the existing Freon before repairing or replacing the faulty part.
This ensures that the system can be properly serviced without the risk of refrigerant leakage during the repair process.
Refrigerant Replacement
Over time, older refrigerants such as chlorofluorocarbons (CFCs) and hydrochlorofluorocarbons (HCFCs) have been phased out due to their harmful effects on the environment and the ozone layer.
If a refrigerator contains these outdated refrigerants, it may be necessary to remove them and replace them with newer, environmentally-friendly refrigerants, such as hydrofluorocarbons (HFCs).
Disposal or Recycling
When a refrigerator reaches the end of its life or is being replaced, the refrigerant must be properly removed before disposal or recycling.
This is to prevent environmental pollution and ensure compliance with regulations regarding the handling and disposal of refrigerants.
Regulations Regarding Refrigerator Freon Removal
In many countries, the handling and disposal of refrigerants are subject to environmental regulations to prevent harm to the ozone layer and mitigate climate change.
Regulations vary by region. In some states, certified technicians are required to handle freon removal. These professionals have undergone proper training and certification for handling refrigerants.
Therefore, they are knowledgeable about the safe and environmentally responsible handling of refrigerants.
Certified technicians use specialized equipment designed for the safe recovery and recycling of refrigerants.
This equipment helps capture and contain the refrigerant, preventing its release into the atmosphere, and its use is the primary reason for many of the regulations in place.
During the removal process, the refrigerant is carefully extracted from the refrigerator and stored in designated containers or cylinders for proper disposal or recycling. The recovered refrigerant is often sent to facilities equipped to handle refrigerant recycling or destruction.
Once the refrigerant is recovered, it should be disposed of in accordance with local regulations. This may involve sending the refrigerant to licensed facilities for recycling, destruction, or proper disposal to ensure it doesn't harm the environment.
Technicians are usually required to maintain records documenting the proper removal, recovery, and disposal of refrigerants. This helps track the handling of refrigerants and ensures compliance with regulations.
Can I Remove Refrigerator Freon Myself?
In most cases, the answer is no. It is not recommended to remove refrigerator Freon (refrigerant) yourself unless you are a certified technician trained in refrigerant handling and have the necessary equipment and knowledge to do so safely.
Handling refrigerants requires specialized tools and expertise to prevent environmental damage, ensure personal safety, and comply with legal regulations.
Refrigerants, including Freon, are potent greenhouse gasses that can contribute to climate change and harm the ozone layer if released into the atmosphere. Improper removal or release of refrigerants can result in environmental pollution and is illegal in many jurisdictions.
By entrusting the task to qualified professionals, you can ensure compliance with regulations, protect the environment, and prioritize your own safety.
professional repairing refrigerator
What Does the Process Involve?
Even if you’re not the one that ultimately does the job, it’s important to know what it entails.
The first step is to contact a licensed HVAC (Heating, Ventilation, and Air Conditioning) professional or a refrigeration specialist who is certified to handle refrigerants.
The technician will assess the refrigeration system to determine the type of refrigerant used and the condition of the equipment.
The technician will set up specialized recovery equipment, such as a refrigerant recovery machine and appropriate hoses and fittings, to safely extract the Freon from the system.
The technician will connect the recovery equipment to the refrigeration system and initiate the recovery process. The machine will pull the Freon from the system into a recovery cylinder, containing and capturing the refrigerant.
Once the bulk of the Freon is recovered, the technician may use a vacuum pump to remove any residual refrigerant and moisture from the system. This helps prepare the system for servicing or disposal.
The recovered refrigerant is stored in recovery cylinders, which are properly sealed and labeled. The technician will handle and transport the cylinders.
The material is disposed of or recycled according to environmental regulations and best practices. Recycling involves sending the refrigerant to specialized facilities where it can be purified, treated, and reused.
If recycling is not feasible, the refrigerant may be sent for destruction to ensure it does not harm the environment.
What Specialized Tools Are Needed for Refrigerator Freon Removal?
Note this information is for reference purposes only, and it is not intended as a guide for non-professionals.
Refrigerant Recovery Machine
A refrigerant recovery machine is a device specifically designed for the removal and recovery of refrigerants from appliances. It helps to extract the refrigerant from the refrigerator while containing it within the system to prevent its release into the atmosphere.
Recovery Cylinders
These are specially designed containers or cylinders used to store the recovered refrigerant. The cylinders are equipped with valves and fittings that allow the technician to connect them to the recovery machine and seal them to prevent leaks.
Manifold Gauge Set
A manifold gauge set consists of gauges, hoses, and valves used to monitor and control the pressure and flow of the refrigerant during the recovery process. It helps the technician assess the condition of the system and ensure a safe and efficient recovery.
Vacuum Pump
A vacuum pump is used to remove any residual refrigerant and moisture from the system after the initial recovery process. It creates a vacuum in the system, allowing for a more thorough evacuation.
Refrigerant Identifiers
These devices are used to analyze and determine the type and purity of the refrigerant being recovered. They help ensure the correct refrigerant is being handled and can alert the technician if there are any contaminants or mixed refrigerants present.
Personal Protective Equipment (PPE)
Certified technicians also wear personal protective equipment, including gloves, safety goggles, and respiratory protection, to ensure their safety during the refrigerant removal process.
Safety Concerns of Removing Refrigerator Freon
The removal of refrigerator Freon involves certain safety concerns that need to be addressed by trained and certified technicians.
Inhalation Hazards
Refrigerants can be harmful if inhaled. They may displace oxygen in the air, leading to asphyxiation in confined spaces.
Technicians must ensure proper ventilation during the removal process and wear appropriate respiratory protection if necessary.
Chemical Exposure
Direct contact with refrigerants can cause skin irritation, frostbite, or chemical burns. Technicians should wear gloves and other appropriate personal protective equipment (PPE) to minimize the risk of skin exposure.
High Pressure
Refrigerant systems operate under high pressure. Incorrect handling or accidental release of pressure can cause injury. Technicians must follow proper procedures to safely depressurize the system before removal.
Flammability
Some refrigerants, such as hydrocarbons, are flammable. Technicians must be aware of the flammability properties of the refrigerant being handled and take appropriate precautions to avoid ignition sources and maintain a safe working environment.
Environmental Impact
Refrigerants, particularly older types such as chlorofluorocarbons (CFCs) and hydrochlorofluorocarbons (HCFCs), can have harmful effects on the environment if released into the atmosphere.
Technicians must ensure proper containment and recovery of the refrigerant to prevent environmental pollution.
Compliance with Regulations
There are legal regulations governing the handling, recovery, and disposal of refrigerants. Certified technicians are trained to comply with these regulations to protect the environment and ensure legal compliance.
Freon removal is a cumbersome process, especially in light of the discovery that Freon actually causes considerable harm to the environment.
Combined with the many regulations in place, meant to protect you and the environment, it’s best to let a professional tackle refrigerator Freon removal.
How to Locate a Freon Removal Specialist
To find a certified refrigerant handling professional or an appliance repair service that employs qualified technicians, start with a bit of research in your area.
Conduct an online search or ask for recommendations from friends, family, or neighbors who have recently used appliance repair services.
Look for businesses that specifically mention expertise in refrigerant handling and certifications in their service offerings.
Once you locate a few technicians, verify their certifications and licenses.
You’ll see certifications such as the Environmental Protection Agency (EPA) Section 608 certification. The EPA certification indicates that technicians are trained in handling refrigerants safely and legally.
Additionally, verify that the appliance repair service holds the necessary licenses and permits required by your local regulatory authorities.
Another route to finding a Freon removal expert is to reach out to professional organizations in the HVAC (Heating, Ventilation, and Air Conditioning) industry.
These organizations often maintain directories or can provide referrals to certified technicians or reputable appliance repair services in your area.
When scouring the internet, locate online directories that specialize in listing appliance repair services or contractors.
Look for businesses that specifically mention refrigerant handling expertise or certifications in their profiles. Check customer reviews and ratings to get an idea of their reputation and quality of service.
Another quick way to gather information is to contact local appliance repair companies.
Reach out to inquire about their technicians' certifications and experience in handling refrigerants. Ask if they have technicians who are certified by the EPA or other relevant organizations.
However you come across potential technicians for your project, take the time to request proof of certification. It’s worth the additional effort to ensure the safety of the worker and your home, as well as the environment.
Reputable technicians and companies should be transparent and willing to provide this information.
Remember to ask about their experience, the range of appliances they service, and any warranties or guarantees offered on their work. Obtaining multiple quotes or estimates can also help you compare services and make an informed decision.
Even though Freon removal may not be a recommended DIY task, you can tackle plenty of other repairs. Review Common Refrigerator Problems and How to Solve Them, and take a look at Repairing Your Refrigerator for more information.
