Reinforcing Mesh Reinforcing Mesh
Along with using rebar to strengthen concrete, you also have the use of reinforcing mesh. This is actually steel wires that are welded into a grid. These spaces are usually around 6-10 inches wide.
They are, along with rebar, placed in wet concrete in order to make it solid. When the concrete dries, the concrete is more solid and can withstand a lot of weight and pressure.
How Does Reinforcing Mesh Help?
Reinforcing mesh helps prevent cracking in concrete. You can most often see this technique used in driveways. Driveways are one of the most likely places you will see cracks. Using the reinforcing mesh will help prevent cracks.
Where are Reinforcing Mesh Mats Placed?
Reinforcing mesh is placed in flat surfaces. This can include the slabs on the ground, walls and more. This mesh helps improve construction times. It considerably reduces the amount of time it takes to reinforce the concrete. Not only do these measures make it more time efficient, but they also make it a safer construction.
