Removing a Stripped Hex Bolt
  • 1 hours
  • 0-100
Hex driver
Screwdriver
Rotary tool
Cutting wheel
Extractor
Lubricant
Hex driver
Screwdriver
Rotary tool
Cutting wheel
Extractor
Lubricant
A stripped hex bolt often puts a pause to the job at hand. You might have come across this problem and must have spent hours trying to fix it. Read on to find out about a few common and easy ways to remove a stripped hex bolt.
Step 1 – Safety Precautions
This job does not involve the use of any complicated equipment. But, it would be advisable to take the necessary safety precautions. Wear your work glove at all time. Also safety goggles will come handy.
Step 2 – Hex Driver
In order to remove a stripped hex bolt you will need a hex driver. While buying the hex driver make sure you measure the stripped hex bolt's head. The driver should be one size bigger than the head.
Step 3 – Use the Driver
In this step you will learn how to use the driver. Place it onto the head of the hex bolt. Twist the driver to free the hex bolt. Because the driver is bigger it helps in removing the stripped hex bolt.
Step 4 – The Screw Method
The above explanation was just one of the methods to remove a stripped hex bolt. Another method is to convert the stripped hex bolt into a screw. This will help you remove it from its position.
Step 5 – Cut the Head
You need to introduce a deep cut onto the head of the hex bolt. Use a rotary tool as well as a cutting wheel to accomplish this.
Step 6 – Screwdriver
Get hold of a screwdriver; make sure it is flat headed. Place the screwdriver on the cut that was created in Step 5 and turn it around. After a series of turns the bolt will come free.
Step 7 – Cut the Head
Another method to remove the bolt is to cut off the head. You need to use a rotary tool for this. Also an extractor will help you in this process.
Step 8 – Position
The rotary tool has to be positioned extremely close to the hex bolt head. Now get a drill bit and an extractor of the exact same size. Now drill the hole at the bolt's center
Step 9 – Extractor
In this step introduce the bit of the extractor into the hole drilled in Step 8. Make sure that you introduce the bit gently and in a straight direction. Moving it sideways will result in breaking the extractortor bit.
Step 10 – Turn Counter Clockwise
Once the bit has penetrated the hole completely, turn it in the counter clockwise direction. This will result in releasing the grip of the hex bolt and it will break free.
Step 11 – Lubricate
Before you start with the removal process you should lubricate the bolt. Lubricating the bolt will help in providing ease while threading the bolt out.
Step 12 – Machine
If you have some extra bucks to spare then you can buy one of those semi automatic tools that help in removing the stripped bolt. This will require you to heat the bolt's head and stripping the end with the help of the machine.
