Removing Windows in Brick Veneer Siding: Mistakes to Avoid Removing Windows in Brick Veneer Siding: Mistakes to Avoid
If you want to remove windows from an area which has brick veneer siding, then how you manage this will depend very much upon whether you wish to keep the siding or not. You could simply remove the brick veneer siding using a crow bar, but this would damage the siding, and if you wish to retain it, then you will have to use another method. By avoiding some simple mistakes, you should be able to remove the windows very easily.
Avoid Large Tools
When you are removing the nails which hold the window in place, use the smallest possible tools that you can get away with. This may take slightly longer, but you should coax out any nails, rather than trying to drag them out. This will help you to avoid marking the brick veneer siding accidentally.
Ease out the Frame
Pulling out the frame too quickly will also cause damage to the brick veneer siding. Rather than doing this, you should try and dismantle it in separate portions. If you have a wood framed window, for example, remove the glass and saw through the frame from the inside. You could use a hacksaw to go through a metal frame in a similar fashion.
