Repairing a Solar Electric Fence Charger
Galvanized Copper
Ground Rod Clamp
Ground Rods
Wire Connectors and Clamps
Multi Tester
An electric fence charger is something that you will have to take great care in repairing. It can be a very dangerous thing to work on, especially if you are unprepared and do not take the proper precautions in fixing it. Be sure that you use caution and take all necessary safety precautions before you begin work on your solar electric fence charger.
Step 1 – Repair
The first thing that you will need to do when repairing your solar electric fence charger is to know what it is that you are repairing. You will need to isolate the problem and see what you can do about fixing it while disturbing as little as you can from the rest of the fence. The best way that you will be able to repair your fence is to try to get all of your panels exposed in the sunlight at the same time. Once you have this you will need to use your multi tester on your panels.
Step 2 – Wiring
You will need to get to your wiring to fix it. You may be able to get to the wiring that is in between each of the cells. If this does not work, you may want to try getting to the wiring that is at the complete opposite end of your panel. Do this by cutting into the panel backing.
Step 3 – Installation
You will need to install the pieces that you had to repair. Before you begin, you will need to be sure that the controller is completely grounded. You will be able to ground this with the help of a ground rod. It will need to be connected to the fence controller electrically. Using about six foot of galvanized ground rod, you will need to be sure that it is installed about twenty feet from the actual fence controller. The ground rod will need to be attached to the ground wire, do this with a ground rod clamp.
Step 4 – Connections
You will need to be sure that you make the best connections possible. In order to do this, you will need to use not only wire clamps but wire connectors as well. Make sure that you have the right splices for the job or it will take away from the power on your fence.
Step 5 – Professional Assistance
If at any time you begin to feel like you cannot handle this task then you should consult a professional. You will be putting yourself and others at risk if you attempt this task and are not comfortable or prepared for it. Make sure that you understand all of the safety procedures that are necessary. You will need to have a good and basic understanding about this type of fence and what the procedure to fix it will entail. If you do not feel like you are able to do this then you should not. Ask for assistance from a more qualified person or simply hire a professional. Electrical fences can be very dangerous if they are not properly installed or cared for.
