Repairing Holes and Scratches in Mahogany Wood
Mahogany wood is one of the most coveted hardwoods by homeowners. This is partly because of its smooth grain pattern and attractive color. The wood has a unique pink color that turns into a reddish-brown shade with time. Some of the items that mahogany is used to produce include pianos, flooring, furniture and boats. Mahogany is an extremely strong and durable hardwood. However, damages do occur even to this well regarded hardwood. These may include holes and scratches in the wood. The steps below show you how to repair holes and scratches in your mahogany wooden items.
Materials Needed
  • Fine grit sandpaper
  • Old toothbrush
  • Wood putty
  • Beeswax
  • Blunt knife
  • Sealant
  • Soft cloths
  • Warm water
  • Mineral spirits
  • Iodine
  • Paintbrush
Step 1 – Clean the Hole
Use an old toothbrush to remove dirt and debris from the hole in the mahogany. Dip a cloth in warm water and wring. Wipe through the hole and around the surface with the cloth. Allow the hole to air dry for an hour.
Step 2 – Fill the Hole
Place some wood putty into the hole. Fill the hole to the brim and allow it to dry overnight. If you find that the putty has shrunk the following morning, apply more to create a uniform surface with the adjacent wood. Allow sufficient time for the putty to dry once more.
Step 3 – Finishing
Remove the excess putty with a blunt knife. Buff the repaired area with sandpaper to give it a uniform appearance with the adjacent wood. Apply a suitable wood sealant for mahogany.
Step 4 – Minor Scratches
Rub along the scratch with fine-grit sandpaper. Be sure to rub in the direction of the wood grain so that you retain the uniform appearance of the wood. Wipe away the dirt and debris from the area with a damp cloth. Allow 2 to 3 hours for the wood to dry adequately. Apply a light coat of iodine onto the scratch with a thin paintbrush. The iodine helps to restore the color of the wood. Let the iodine sink into the wood until it dries. If the color hasn’t matched the rest of the wood, brush on some more iodine.
Step 5 - Buff
Once the wood has dried, apply a suitable wood polish onto the area. Buff with a clean microfiber cloth. Buff in several circular motions to give the wood a good shine.
Step 6 – Deeper Scratches
Clean out the scratches with an old toothbrush. Place some mineral spirits on a cloth and wipe the area well to remove dirt and debris. Allow the area to air-dry for 2 to 3 hours.
Step 7 – Apply Beeswax
Use a blunt knife to press some soft beeswax into the scratch. Be sure to press the wax all the way into the scratch. Spread a small amount of wax on the surface of the scratch as well. This will ensure that the damaged area is completely sealed all the way to the surface to help protect the wood. Allow the beeswax to harden overnight.
Step 8 – Sealing
Remove the excess beeswax with a blunt knife. Apply a sealant suitable for mahogany wood.
