Replacing Broken Window Glass
Whether it’s a baseball, a rock or a bird, they always almost seem to find your windows and you instantly have a hole and lots of broken window glass. If it has happened more than once, it may seem to be tiring to be going through the same thing over and over again. It may get frustrating having to spend all that time, money and effort on something that you feel like you'll be replacing again before long. However, there are some alternatives and other techniques for replacing broken window glass.
Wire Glass
Installing wire glass is an alternative process in replacing broken window glass. It increases the level of safety brought by ordinary glass. A wire mesh is inlaid in the glass, to prevent it from shattering. Its primary purpose is to withstand fire, and is an excellent upgrade for basements and cellars, but will also work any place in your house. It is actually recommended that installing wire glass be left to a professional, since it is a specialized type of glass. Installing it yourself could do more harm than good.
Tempered Glass
This particular type of glass is much more durable than ordinary glass. This is another option that you may want to consider, when replacing your broken window glass. Usually preferred by automakers, due to its strength, tempered glass can be installed in a few easy steps. You can purchase this at your local glass store. However, you need to tell them the exact measurements that you need, because you cannot cut glass that has been tempered. Once you have the specifications of the glass, you can now install it as normal.
Laminated Glass
Laminated glass is another durable option for your broken window. It has a plastic film sandwiched between 2 sheets of glass. When the glass shatters, the plastic film between will catch most of the glass fragments instead of it falling everywhere. These panels are usually held on by a metal frame and retainer strips. In order to change them, use a flat-head screwdriver to pry off the strips, and be careful not to damage them. Once the strips are removed, the glass should come off. In putting in a new one, remove the metal frame first and fit in the new laminated glass. Line up the glass on the opening, and have a friend help you do this, while you reinstall the retainer.
Polycarbonate Panels
Although it is not glass and falls under the family of plastic, polycarbonate is a great alternative, because it is much cheaper than laminated glass, and it is almost indestructible. Installing a polycarbonate panel will require cutting the panel, which can be done with a jigsaw. Once you have achieved the exact measurement of the pane, the installation procedure is actually the same as glass. However, the usual glaze may not be able to handle the plastic due to its expanding properties. Instead, use glazing compounds that are silicone-based. This is a great alternative for your broken window glass.
