Repointing Brickwork Stairs
Wire brush
Chisel
Mallet
Spray bottle or hose
Water
Bucket
Trowel
Mortar
Tuck-pointing trowel
The process of repointing brickwork is required if the bricks' mortaring has started to wear away. Brick stairs are highly susceptible to wearing away because they get frequent pressure from foot traffic. Follow the simple steps below to effectively repaint your brick steps.
Step 1 - Removing the Eroded Mortar
To begin, you must remove the old mortar. Eroded mortar is much softer and relatively easy to remove by tapping it away with a chisel and mallet.
Step 2 - Cleaning Up
When you are ready, clean up the dust and debris. You may need to use a wire brush to remove residue from the joints.
Step 3 - Misting
Dampen the brick steps by spraying some water. It is better if they are moistened.
Step 4 - Mix the Mortar
Next, follow the package's directions with regards to the amount of water to add. Make sure to mix it well with a trowel until you achieve the right consistency.
Step 5 - Applying the Mortar
Use a tuck-pointing trowel to start filling up the joints with the mortar. Make sure to fill each space well, and then press the mortar down. Try to be as neat as possible by removing any excess mortar and smoothening it.
